M59 relief valve questions.
   / M59 relief valve questions. #1
Hersheyfarm
Veteran Member
NE ky
I know there is two under the seat but the backhoe has three on the control valve. They are adjustable. If they are set at a very low pressure setting would that not be harmful. Making the hoe weak but producing excessive heat. Now, to set them would I plumb in a gauge for each circuit and set pressure by bottoming out the cylinder for that circuit? Wouldn't the main relief valves kick in?
I seem to have posted this in the wrong forum.
   / M59 relief valve questions. #3
I wouldn't touch them, if in warranty, let them diddle with it.
   / M59 relief valve questions. #4
I have the procedures for adjusting the relief valves. Send me a PM and where I can send you some information.
D&B
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2005 CHALLENGER 500 BBL FRAC TANK (A53843)
2005 CHALLENGER...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
