M59 exhaust manifold leaks and turbo oil line.
   / M59 exhaust manifold leaks and turbo oil line. #1
Hersheyfarm
NE ky
My m59 started sounding like valves slapping, especially under load at low rpm's. Kubota recommends valve adjustment at 800hr I think. We have a new kubota dealer here now so I scheduled with them. It's a very annoying noise. As I investigated I found the leaks. You can feel the leaks blowing out at idle. Will still go forward with valve adjustment and price them doing new gaskets too. Went ahead and started spraying pb blaster on nuts of manifold. Surprising they move pretty easy. So just an FYI.
I have no ideal why pics are sideways but when I click on them they expand right side up, but this is the leaks. Very easy to find with the soot. Also a pic of my turbo oil line leaking. I'm sure it's just o-ring. The exhaust leaks are #1 and #4 cylinder.
   / M59 exhaust manifold leaks and turbo oil line. #3
The turbo oil line leak is a crush washer.
I did try to snug up but turbo has to come off for exhaust gaskets. I ordered both oil line washers with exhaust gaskets.
This tractor is very sluggish at low rpm. It has to be loss of boost from leaks. It was gradual but in the last few hour has gotten pretty substantial.
   / M59 exhaust manifold leaks and turbo oil line. #5
Just out of curiosity, how many hours are on it?
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
UNUSED TOPCAT ECSSS7G200 HYD STUMP GRINDER (A51248)
UNUSED TOPCAT...
2016 CATERPILLAR 306E EXCAVATOR (A51246)
2016 CATERPILLAR...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
