M59 AutoThrottle ON/OFF
/ M59 AutoThrottle ON/OFF #1
buck1974
Smiths, ALabama
Had my M59 for little over two months now, and just noticed something I found that I like fairly well. Its the Autothrottle, It can be switched to the ON/OFF position. I'm one to always want the motor to warm first before I take off. So I sit and wait a couple of minutes before I do petal down to take off. I have read the manual, and looked everything over several times and seem to find something different each day. I just found that I can switch the autothrottle to OFF and petal down and the RPM's stay at idol the whole time while traveling. I really like that feature as I love for the motor to warm first, but now It can be warming up while riding to do the first job. I really don't know what exactly its used for, but for me I use it for that.
This is my second Kubota first one was a 3130 with loader which was an excellent tractor by the way. I sold it and now have the M59. However, I read a few post about the M59 and its great at what it does, but if I was better off I see now how much easier it be if I owned a excavator and a skid steer from Kubota of course. That would be the ultimate setup. Strickly my opinion. I know this was a useless thread, I just wanted talk about the M59 as I see very few post on this tractor.
/ M59 AutoThrottle ON/OFF #2
Be cauful when doing this on a cold engine, you are keeping your engine at idle, but you are putting a high load on it by pushing the pedal all the way down on a cold engine. You are really not doing yourself any favors here. Just let the engine warm up until you see movement in the temp gauge (your manual has more details), then move. I use the auto-throttle for everything except pto work. It is especially nice for FEL work. When you do not need engine speed, it automatically slows down to save wear and fuel. Philip.
/ M59 AutoThrottle ON/OFF #3
Had my M59 for little over two months now, and just noticed something I found that I like fairly well. Its the Autothrottle, It can be switched to the ON/OFF position. I'm one to always want the motor to warm first before I take off. So I sit and wait a couple of minutes before I do petal down to take off.......
(SNIP)
.......Strictly my opinion. I know this was a useless thread, I just wanted talk about the M59 as I see very few post on this tractor.
You know, there used to be a lot more M59 threads and posts. When the M59 first came out a guy named Charles started a thread where all of us early M59 owners could share info about this new species of Kubota. Charles's idea was to create an M59 library of information that we could all use and expand on as the years went by. I think it was about 20 pages of excellent info. But when I just went looking for it I couldn't find it!! What happened to the thread? Am I looking in the wrong place???
As for the auto-throttle I do the same on mine, and for the same reason. Generally I'll try to let it idle for a few minutes to get the hydraulic fluid warm. That's always the best practice, but there are plenty of mornings when I still prefer not having the darned autothrottle reving the motor up to full chat when all I want to do is motor sedately down the lane while looking at the morning.
In fact, even when I'm working around the yard I don't need the auto-throttle's preference for reving and roaring the motor's readiness for hard work when all I'm doing is some light contemplative dirt moving or maybe placing some rocks around the garden with the backhoe and thumb. The M59 is a big capable machine, and frankly there is a lot of work it can do just fine slowly & at a nice quiet idle. No need to bellow about it.
There is one thing I'm careful about doing when the autothrottle is off. That is not to press for more speed from the tranny so that it causes the engine to lug; never deliberately lug the engine. Some mornings I just give it enough foot on the hydrodrive to move over the ground without lugging. That gets up going somewhere, reduces the time that the engine and transmission have to spend warming up (BTW, that reduction in time is the basis for an ongoing debate among engine designers) and has the extra benefit of not causing my coffee cup to bounce around in the cup holder. If it does begin to lug and you feel the need a bit more power, the manual hand throttle is right there conveniently next to your autothrottle switch. Just increase the idle a few hundred RPM and things will smooth out. You've probably already noticed all of that.
Best, rScotty
/ M59 AutoThrottle ON/OFF #4
Best, rScotty
I am subscribed to that thread too, but don't see it in my subscribed list! However it turns up in a search for "M59", titles only. Some other posts have reported issues with subscriptions. BTW as a new M59 owner I have found these threads to be enormously useful, both in deciding what tractor to get as well as for attachments and techniques. Thanks much to everyone who takes time to post (including you rScotty, also CharlesAF, ManAtWar, Chato, and so on! The accumulated experience collected here is invaluable).
Personally I rarely use the autoThrottle, I prefer manual throttle. In colder weather, the first time I always let it warm up until I get 2-3 bars on the temperature readout, with the HST engaged, before I go anywhere. Nothing wrong with giving it 10 min to warmup. I usually run about 2K RPM, sometimes higher if I am working it hard. I am happy with the power, although the swing on the hoe seems weaker than it I would expect.
/ M59 AutoThrottle ON/OFF #5
I am subscribed to that thread too, but don't see it in my subscribed list! However it turns up in a search for "M59", titles only. Some other posts have reported issues with subscriptions. BTW as a new M59 owner I have found these threads to be enormously useful, both in deciding what tractor to get as well as for attachments and techniques.....
Thanks for the search hint. Using your info I went to the FORUMS home page and did a search under M59 for "titles only". I also put Charlesaf3 in the User search box and identified him as the the person who started the thread.
Amazingly, the search found the previously invisible thread. So I answered the last post on that thread, figuring that an answer might somehow update the whole thread into today's messages.
Guess what? It Worked! Now the 24 page "M59 Discussion Thread" again shows up today and hopefully will continue when we search this Kubota Operating/Owning forum for M59 info. There's a ton of info in those pages. And probably some questions as well. Take a look.
I wonder how many other good old threads have dropped off the radar?
enjoy, rScotty
You are absolutely correct on the swing of the backhow from Left to Right. I like to work sometimes with out having the RPM's up. However, when the RPM's are low the swing of the boom left to right is so weak I had my brother stand beside it and he actually stopped it from moving with his body weight and he is 200 lb guy. Although, I have to raise the RPM considerably high more so like 2800 rpm's to get the power I need with the backhoe. I just wished they would go through a test of all TLB's and complete pressure test and check all hydraulic funtions before it ever leaves the factory. How many times have you heard that owners don't think their FEL, Backhoe has the power it should have. I sometimes think I have issues with mine from time to time not having enough ummp. You hear all the time of people suggesting to pressure check the HYD. I think all of this should have had a complete run through at the factory. When I my M59 come in the first of Feb 2012, I was told it will be a day before I receive the tractor as they have to add the Hyd fluid and grease everything up prior to delivery.
/ M59 AutoThrottle ON/OFF #7
enjoy, rScotty
I've probably read that whole thread through twice now, once before I got the M59 and once after having it for a while. Immensely useful to have these discussions archived in the forum!
/ M59 AutoThrottle ON/OFF #8
This is exactly what I am seeing too - it doesn't take much to stall the swing. So probably this is normal, which is good. Obviously the mechanical advantage of the swing is awful but it looks like it should be stronger than it is. At some point when I have the hoe off I will check the relief pressure on the swing circuit. Nonetheless it still works fine! The M59 hoe has plenty of power for digging and stump removal. It easily lifts the whole back end of the tractor off the ground, as it should.
/ M59 AutoThrottle ON/OFF #9
Uh oh...it sounds like both you guys are worried about the BH swing and I can see why. Maybe I can help just a little. I've an idea - so skip to the bottom of this message if you want. Most of the in between is just rambling.
The important point is that my M59 BH sounds like it has more swing power.
I do agree with low RPM work; I prefer it too. Theoretically for a positive displacement hydraulic system the RPM shouldn't make a difference in power...only in speed. But in the real world with manufacturing tolerances and fluid properties being variable more RPM means more power. On my M59 the difference isn't all that great. Higher RPM just means faster motion and more opportunities to jerk the BH bucket around and make a real hash of delicate work.
I'm not sure I would want any more BH power on this tractor. It would be nice to have some more reach maybe, but as it is I sometimes wonder if the tractor is over-stressing itself. The BH can sure throw the tractor around. And if the BH has enough power to move the tractor around, how much more power can it use?
I was moving boulders around in the creek yesterday and never did take it above an idle. Since I'm backed up to the edge of the stream, a lot of the work involves tumbling piles of rocks around using the bucket curled and the swing at full extension. That loads all the BH pivots rather too much; so I'm careful with the power. If it pushed sideways with any more power my gut instinct is that something expensive would break. The swing is the least powerful BH motion, but it still has enough force to make the whole tractor creak.
Of course this is all perception. We don't have any real numbers between yours and mine, and that's what we need. Yours and mine might well be the same or close. I'm not expecting the M59 to be an industrial strength backhoe....just sort of an in between. Have you any suggestions? I don't have a 200 pound brother handy, but am open to ideas. Are there any specs in the service manual? What does your dealer say? What pressures are you getting? We could probably compare those types of numbers fairly easily.
BTW I'm just remembering that when I first got my machine the BH made terrible screeching/moaning sounds as it swung. I don't know if that would affect the swing power or not. Might. On mine I just didn't like the sound. It sounded to me that either the fits were too tight or someone had not properly greased all of the pivots for the swing. Considering that most Japanese equipment is manufactured to excellently tight tolerances, I wondered if someone had missed some grease zerks. There are a surprising number of zerks for the swing table, pivots, and swing pistons....but they all looked to be serviced. I put in more grease anyway, but it made no difference. The screeching noise was pretty loud...right at the level where it needed to go back to the dealer, but really.....what is he going to do? I decided to give one more try to change things before returning the machine.
The thing was, I got to wondering if both Kubota and myself had been using the proper grease. The grease I forced out when I put some in looked pretty ordinary, and I knew I had used ordinary ol' wheel and chassis grease myself because I had just run out of good grease in my shop.
Upshot was I used the event for an excuse to buy a really good hand grease gun along with some cartridges of a special high pressure grease loaded with molybdenum. That's a black, rather thin grease, and oddly sticky. I've used it before for similar tight sliding friction on industrial slides and also for breaking in high performance camshafts on racing motors. It's an expensive grease - at least 3 or 4 times the cost of regular wheel & chassis grease. So I only use it on the lower BH zerks; ....I don't want that nasty sticky black grease all over the loader pivots and myself. There sure are a lot of different greases for different purposes. Here what was wanted was a grease that could get into tight spaces, stay there, and stand up to point loading. The only one I know that will do that is a fairly thin black moly grease. Had to go to several shops before I found some. A local hotrod shop had it in grease gun cartridges.
Anyway, I used the new to force out most of the old grease, and the sound went away the very first swing. Very gratifying. I don't know if the swing power changed, but it sure cured the sound.
Hope this helps, rScotty
/ M59 AutoThrottle ON/OFF #10
Mine does have a problem with the main swing bearing; I can barely get any grease in and that is with my 7K PSI powered grease gun. I got some solvent (Blaster 16-PB) which I plan to use to try to clean out the bearing. I like the idea of a thinner grease given that this bearing is so tight. I am dubious if that will affect the delivered swing power much but sure don't like having a main bearing which is not fully lubed.
rScotty it seems clear from your description that yours has more power in the swing. With mine it isn't even close to stressing anything in the swing. Other than that sure the hoe can throw the tractor around, and is plenty strong for the relatively light M59.
/ M59 AutoThrottle ON/OFF #11
Is that main bearing it making noise? How do you know it isn't getting fully lubed?
Also wondering about the 7K psi....Is that one of the air-powered grease guns? The manually operated hand-lever types advertise that they generate more pressure. Usually in the 10 to 15K range. If true, that might help.
But I gotta confess that the real reasons I went out and bought a separate grease gun for the moly grease was to keep it separate. I could only use it where absolutely necessary. It's nasty and messy stuff to handle; costs more and stains anything it touches. I use more user-friendly grease most everywhere else, so it helps to have two manual guns.
rScotty
/ M59 AutoThrottle ON/OFF #12
rScotty
The main bearing isn't making any noise, but then I bought it used whereas you had the screech when yours was new. I know it isn't getting fully lubed because I don't get grease out all around the bearing when I pump grease in (but then I can't pump much in either!). Probably the original owner didn't get much in either, and what there is in there is hardened. Hopefully the PB will loosen things up because I sure would not want to try to pull those pins!
My powered grease gun is a rechargeable battery powered unit - I got it to pump a lot of grease more quickly (the tractor must have 30+ grease spots and my trailer also is a grease hog). I will be getting a separate gun for the special grease for the same reasons you mention. I will look for a high pressure model.
Anyway, this is encouraging, since you spotted the swing bearings as a possible issue while I already know I have an issue. I will let you all know how it turns out (I won't be able to get back to this for a while though).
RoGator RG1300C (A63688)
RoGator RG1300C...
Kubota GR2020G (A63688)
Kubota GR2020G...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
