M5660 SUHD Rear wheel question.
   / M5660 SUHD Rear wheel question. #1
Helitech
Aberdeen, MS
5220R Branson, 1256 International
Looked at another 5660 today at a local dealer, this one had rear wheel hubs that were huge! They weren't bolt on wheel weights, very thick, probably 8" or more. Didn't see them on the option list on Build a Kubota. Anyone know anything about these? How much they weigh?
   / M5660 SUHD Rear wheel question. #2
700lbs according to my owners manual. It is called the "Cast Iron Disk option". I have them on my tractor along with fluid in the tires. The fluid in the tires adds about 250lbs per tire. I very seldom need to kick in the front wheel assist, the traction with the weight and R1's is great.
One bad point about this tractor, visibility to the leading edge of the forks is non existent, so I mounted a camera to the loader and put the monitor in front of the steering wheel. This is a real slick setup. Now I can precisely place the forks for pallet work and not pierce anything that should not be.
I like this tractor more every time I climb on it. It does not have all the bells and whistles, but that is why I bought it. It is a great utility tractor that can do some serious work.
700 per side?
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
18in Wain-Roy Tooth Bucket (A51573)
18in Wain-Roy...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
