M5040 vs Grand L GST
   / M5040 vs Grand L GST #1
SCDolphin
Columbia, SC
Kubota L5240: Craftsman GT6500
I need info on operation the Hyro shuttle vs the normal HST systems. I can't decide between the ne M5040 vs the GL4630 GST. I will be doing a lot of fel work.
When using the shuttle shift on either model with RPM set at lets say 2000 rpm, do I have to bring it to a complete stop and clutch to go forward - reverse? On the JD e-reverser no clutch is needed and the rpms can remain high going forward -reverse.
   / M5040 vs Grand L GST #2
No clutch required shifting gears, or changing direction. you could almost take the clutch pedal off. with the GST. I sometimes use it parking close to the wall in the shop. but most of the time just use the shuttle lever. I like it
Good Luck. WW
   / M5040 vs Grand L GST #3
</font><font color="blue" class="small">( No clutch required shifting gears, or changing direction. you could almost take the clutch pedal off. with the GST. I sometimes use it parking close to the wall in the shop. but most of the time just use the shuttle lever. I like it
Good Luck. WW )</font>
Do you have to decrease engine RPM when using the GST? Or can you keep the engine at 2000 RPM while changing forward to reverse and back?
   / M5040 vs Grand L GST #5
</font><font color="blue" class="small">( No need to change the RPMs. )</font>
Good to know. The GST is one tough tranny!!!!
Bob
Craftsman YTS 3000 42in. Riding Mower (A49346)
Craftsman YTS 3000...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2022 John Deere 325G Skid Steer (A50657)
2022 John Deere...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
PICK UP BED (A49461)
