M5-111 Clutch operation
   / M5-111 Clutch operation #1
rwskinner
South Texas
2011 M7040-DTC (4x4 CAB)
I have a new M5-111 on order but it's not scheduled to come in until the first of next year. I did get the chance to drive one today.
That clutch seems to be pretty abrupt and difficult to feather. For example, inching back to implements, or using the bucket to place a load.
Now, I come from a manual syncro shuttle 7040 so some of it's may be just the difference in feel and something I have to get used to.
Do you have experience with a M5-091 or M5-111 and what's your opinion on the clutch?
Other than that, cab is larger and quieter, and the clutch pedal does seem a little easier to push. Nice tractor.
   / M5-111 Clutch operation #2
I have an M5-091, the clutch does take some getting used to. It uses hydraulic clutch packs, there is some delay in clutch apply when trying to inch especially with cold oil. The simple way to look at it is, let the clutch pedal up a little bit and wait for it. You will get used to it. It is one nice tractor, I should have gone for the M5 instead of starting with an M7060.
Thanks for the response. Yes it was cold oil when I tried it. I use a front mounted hydraulic limb cutter and my 7040 allows me to move very slowly into position, but by the end of the day my left knee doesn't work anymore (getting some miles on myself). After test driving that M5, I thought to myself that precise inching may be impossible so I'm glad to hear it's not an issue and I just need to get used to it. For other task I don't see it being a problem at all.
   / M5-111 Clutch operation #4
I am guessing your 7040 used a dry clutch rather than hydraulic clutches. My M5 is a 12 speed, I can't speak to clutch operation with an M5-111 with a 24 speed transmission, it is probably a safe bet to say they are very similar. The M5 are very nice machines!
   / M5-111 Clutch operation #5
Ditto M7060 sync-shuttle utilizes a dry traction clutch. I'll guess M5-111 is similar to my M7040 HDC & utilizes a hyd valve attached to foot pedal to control wet shuttle clutches.
   / M5-111 Clutch operation #6
"Hydraulic Shuttle" clutch pedal doesn't feel the same as a normal dry clutch, not as precise for sure.
Things "feel better" when the oil is warmed up and you use low gears for precision work.
   / M5-111 Clutch operation #7
What sort of hydraulic limb cutter do you use? Driven by tractor hydraulics or by PTO driven pump?
Limbhog running from a rear remote with hoses running to front. 12 hp with reverse if you jam it. Absolutely love it.
   / M5-111 Clutch operation #9
Is that similar to a LaneShark? I use a Lane Shark [which works great] and previously tried larger heavier FEL mounted cutters with too little hydraulic flow from the tractor for them to be robust.
No, it's a 18" chain saw driven from a 12 hp hyd. motor. It's on a 8-10' extension made from 2-1/2" square tubing. Chain saw on a long pole.
You can google Limbhog and there are a couple of others that are almost exact copies. It's good for trimming trees by yourself. A man basket and a pole saw works wonderful you you have a helper.
I mounted my Limbsaw receiver to my grapple. I open my grapple wide open then disconnect the hoses and hook my saw up. As limbs fall and pile up, I can use the grapple to push them out of the way. When done, sliding the saw off is quick and then plug the grapple hoses in and clean up all the piles.
  • Good Post
Reactions: JWR
2015 Chevrolet Silverado 3500 Knapheide Service Truck (A55973)
2015 Chevrolet...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
2014 Kia Optima (A56859)
2014 Kia Optima...
SINGLES TREES & HAYNES (A58374)
SINGLES TREES &...
1993 Generac Olympian 93A 100kVA Towable Diesel Generator (A56857)
1993 Generac...
2016 Freightliner M2 106 Terex Hi-Ranger HRX55 55ft. Insulated Bucket Truck (A55973)
2016 Freightliner...
