M105X front end noise
   / M105X front end noise #1
stuckinmud
Le Center, Mn
Kubota M105X
I bought my M105X new a bit over 3 years ago. I use it on the farm to move large round bales, snow removal, hauling manure, etc. Now it has developed a cracking noise in the right front drive hub area, almost sounds like a dry bearing going bad, but the oil is right where it should be. It only makes the noise with a large round bale on the loader, no noise when driving empty. Anybody had any experience with this???
   / M105X front end noise #2
I would check this:
The 6 bolts that hold the front wheel to the rim will make a crackling,squeeky sound if they aren't torqued real tight. The wheel flexes under heavy load against the lugs on the rim making the noise. I only noticed it under heavy loading or sharp turning. The bolts have a round stove bolt head and a hex nut.
To figure out what the noise was I had to have a friend drive the tractor back and fourth while I walked along side and listened.
I had to tighten mine with a long breaker bar.
Let me know if this is your problem. Good luck.
I would check this:
I checked the bolts as I thought that maybe that was the cause but they are tight, but will re-check them with the weight off the tires and see if that makes a difference. Will let you know.
Just re-torqued the wheel nuts with the wrench that came with the tractor then got out the 3/4 in. air wrench and gave them a little more, and guess what, no more cracking, I had the wife walk along side and nothing. I re-torqued all the front wheel nuts so I hope to be good to go.
Thanks for the tip!
   / M105X front end noise #5
Glad to hear that you got it figured out. Little noises can drive you crazy. ;)
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
2005 John Deere 824J Articulated Wheel Loader (A49461)
2005 John Deere...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2005 GROVE RT700E ROUGH TERRAIN CRANE (A50854)
2005 GROVE RT700E...
BLAST SHIELD (A50854)
