M series steering joint often overlooked
   / M series steering joint often overlooked #1
Dave M7040
Elite Member
Williamstown Ontario Canada
Kubota M7040 Nuffield 465
M5040,6040, 7040 steering joint
For owners of M*040 and M*060 with cab.
There is one splined slip joint in the steering shaft that owners are not greasing and locally one has seized.
It is only visible with the hood open.
Dave M7040
   / M series steering joint often overlooked #2
Good stuff. I'm betting that gets missed a LOT!!!!
   / M series steering joint often overlooked #4
Dave
Thank you for posting that hidden grease fitting location.
Jim
   / M series steering joint often overlooked #5
Just keep in mind that you need a flex hose and a helper to grease it. Not a one person job unless you are extremely flexible which, I'm not. Don't need much, 1 or 2 pumps yearly does the trick.
   / M series steering joint often overlooked #8
That's what I see in the information but I have not physically looked at a non cab tractor in this series
Dave M7040
I'll have to check my openstation M7040SU and see. I'll assume it's the same a regular M7040 ROPS in that area.
It's not in the manual anyways, only 7 grease fittings on the tractor if you include the top link.
   / M series steering joint often overlooked #9
Thanks for posting Dave. I have a M5640 - kind of a mongrel M**40 but I'll be checking to see if I have anything like that.
gg
   / M series steering joint often overlooked #10
It's relative to all the M's far as I know. I have both an OS and Cab model and they both have it. Not a ton of movement on those splines so frequent lube is not required. Like I said previously, one or two pumps yearly is plenty.
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
91013 (A48082)
91013 (A48082)
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2006 HEIL MC407 (A52472)
2006 HEIL MC407...
Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
Caterpillar 279C...
