M-series aftermarket headlight source?
   / M-series aftermarket headlight source? #1
GinNB
NB, Canada, eh?
2x Kubota M108S, M105S, 2x M9000, IH885, IH584, IH484, IH454, F3000, F3610, C50, JX70, Landini 5830, JD4630 sprayer
Has anybody found a place to buy the Kubota headlight bulbs from a place other than the dealer? I'm looking to put some serious light on the tractor and the factory bulbs don't quite cut it. They'll have to stay street-legal but a brighter and whiter alternative would be very nice. The last time I burnt a bulb out and took it around to the local auto parts places nobody had ever seen anything to match it.
   / M-series aftermarket headlight source? #2
We've run into the same thing!
   / M-series aftermarket headlight source? #3
Are your bulbs like these? They are made in 35w and 45w sizes by Eiko. They have what's called a "Y base", having three spring-loaded lugs. My L345 uses Eiko 35watt, the L5450 has 45 watt bulbs (Eiko 6245Y).
Certainly looks like 'em! Thanks. You find any place online or local to buy them? If memory serves, mine had the 35 watters in it.
Aaaannnnnd a bunch of years later I need more bulbs and liberty lightbulb has gone under...
   / M-series aftermarket headlight source? #7
B4 I went LED I hunted for bulbs for my CUT.
I discovered that those CUT bulbs could be found at motorcycle shops.
However I now am all LED equipped and never look back.
Brighter, better, longer life and vibration proof.
Where did you find LEDs bright enough for headlights that fit an 1157 socket? Tons of them out there, but even LED blinker lights aren't THAT bright and I'd worry about the duty cycle on the bright element that isn't meant to run for hours on high.
   / M-series aftermarket headlight source? #9
I did not simply replace bulbs last time but installed a small light bar ($40. ish) that solved al the frontal lighting issues. The old reflector sockets were removed and I blanked off that space.
My light bar has 4 forward spots flanked each side by 4 floods.
I'm on 3 rd winter and no issues at all.
It's 'day and night'.
I went LED and HID on cab corner and loader lights. Hood lights are less important because they light up the buckets but I'd still like them working if needed. Mini light bar in the bash guard would be good though. I just bought a big one to try between the front cab corner lights but haven't had time to mount it yet. It just chaps my butt to pay over $20 for a lousy candle to keep the hood lights lit.
2008 Ford Ambulance (A47477)
2008 Ford...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2006 STERLING CONCRETE MIXER (A55745)
2006 STERLING...
2011 Ford F450 Diesel with Just 156638 Miles (A55302)
2011 Ford F450...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
