M/F 1020 ouestions
   / M/F 1020 ouestions #1
mistermeng
I bought a 1020 and have a couple of questions. Is it capable of using a 5 foot bush on very light weeds or brush? and what is the purpose of two drai plugs in the oil pan. Any info on this tractor would be appreciated. I ordered a service manual but hasn't arrived yet.
   / M/F 1020 ouestions #2
I use 5ft with my 1020 but in light brush cutting. Thick grass I save for the larger tractor. Typically I don't brush cut with the small tractor I'm just too close to the ground for my liking.
I don't remember two plugs in the oil pan. I'll have to check this out next time I'm at the barn.
I had some cranking and electrical issues with my 1020. Turned out to be a dragging starter and bleeding the injector lines. The electrical issue was due to the voltage regulator being bad. You don't want to buy one of those.:eek:
I did try a 5ft tiller. I didn't have enough horse power so I was moving in the ultra slow/slow/slow gear.. Super Turtle is what I call it. If you still have the stickers you know what I mean...:D
   / M/F 1020 ouestions #3
Later model 1010's also have two oil drain plugs; mine does. When you change the oil, pull both of them. Not sure why they are that way. I always wondered if it was to allow clearance for either drive belts or a drive shaft though. I also found out the engine has a higher oil capacity if you have two plugs than if there's only one. I guess overall, the oil pan is slightly larger.
Thanks for your help,I am working on getting a bushog and want to make sure the tractor can handle it.
   / M/F 1020 ouestions #5
I had a 1020 with a 5' brush hog it ran it OK but too heavy and wide. A 4' would have been much better. I used it for my landscaping business to clear brush and saplings. If I remember correctly the two drain plugs are their because the front drive shaft runs through the center of the oil pan. You need to drain both sides.
Dave
Thanks for the information.I bought this tractor to keep eight acres of land mowed down. The land has already been cleared and all I need to do is keep it mowed down. I was thinking a 4ft bushog might be better for the tractor, it would just take a little longer to mow.
   / M/F 1020 ouestions #7
mistermeng -- If your going to have this 8 acres mostly grass you better go with the 4 ft. Thick grass I have to go too slow. Gets boring. I'd rather go faster than slower on my 1020. :D
1995 BEALL TRAILER FUEL TRANSPORT PUP TRAILER (A52472)
1995 BEALL TRAILER...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
Manac Walking Floor Trailer (A50322)
Manac Walking...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52748)
Ditch Witch 6510A...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
