Oil & Fuel M 8540 Leaking Fuel Tank
/ M 8540 Leaking Fuel Tank #1
derekuk101
Bronze Member
KY
M5-111, M8540, M4900, Ford 3600
I've got a small leak from the bottom of the fuel tank around the drainage plug. Nothing has hit the bottom of the tank. We've replaced two seals, one o-ring that sits in the plate that mouts to the tank, and the washer/seal on the drainage bolt. Still leaking. The next step is to replace the small plate that mounts to the tank, but I don't really think it will stop the leak.
Has anyone else had this problem? If so how'd you stop it leaking?
Thanks!
/ M 8540 Leaking Fuel Tank #2
M8540DT/HS/C/H8 50001 ~ 52059
In the M40 series tractors within the serial number range listed above, there is a possibility that you may experience leakage at the fuel drain plate (Item #2 ) due to an uneven surface.
This service bulletin has been issued to make the Dealers aware that a fuel drain seal kit is now available in the event that you come across this type of failure.
Part number 3C081-97050
If you are still under warranty then it should be fixed,.. if not I supplied the part number for the kit that is needed.
Its falls within that range 50165
I'll take this to the dealer on monday. THanks for the info!
