LX565 Intermittent Hydraulic Lift Problem
   / LX565 Intermittent Hydraulic Lift Problem #1
dmroselx565
Please help. My New Holland Lx565 skid loader lift is leaking down intermittently. I had my mechanic check it and have spoken with my local dealer and both thought it was a bad lift check in the control valve. I bought a rebuild kit and my mechanic installed the new lift checks and didn't fix the problem. I went back to the dealer and spoke with service again and they said these are known for wearing out the lift check seat and the only fix is to replace the entire control valve. I followed their guidance and bought a new control valve assy. and installed it. Same problem... My mechanic is stumped, we went as far as tearing down both lift cylinders to check the packing. Both are perfect... I don't understand why the lift will work one second perfectly and then start leaking down. It seems like it happens once the lift arms are lowered all the way down to the bottom. I'm open to any and all suggestions. What are the chances that the new control valve I just bought could be defective? Please advise. Thx. /forums/images/graemlins/confused.gif
   / LX565 Intermittent Hydraulic Lift Problem #2
How new? Where was the tractor made?
I don't know where it was made. I bought the loader used. The intermittent problem I was having has been resolved. Despite the packing looking okay in each of the lift cylinders, we decided to rebuild them anyhow, which solved the problem. Apparently, there was just enough blow by in the hydraulic cylinders to cause intermittment problems with the lift. Hopefully, this will help somebody in the future and prevent them from wasting a lot of money on parts they don't need. Thanks for the reply. /forums/images/graemlins/grin.gif
1999 24DTA pintle hitch trailer (A52748)
1999 24DTA pintle...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A52472)
2015 DRAGON 137BBL...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A52472)
2016 LINK-BELT...
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
