LX279 PTO won't engage
   / LX279 PTO won't engage #1
bfreegv
Grass Valley, Ca
JD LX279, Ford 8N, Branson 2810
Circa 1998 LX279 with 42' deck. The PTO stopped engaging in the middle of a mowing session. My wife was mowing so I don't know the exact sequence of events.
The switch was replaced a couple years ago. I checked continuity was OK on all the terminals when the switch is operated.
If I disconnect the harness jump 12V directly to the clutch it engages. Clutch winding reads ~ 3 OHMS which I think is OK.
Seat switch shuts off engine so I think it's OK.
Reading about similar problems with other models I suspect perhaps either a safety or something on the board failed as I see "PTO relay" mentioned often but I can't find a schematic for this model and I don't know exactly where all the safeties and other involved components physically are.
If someone has a schematic, knows the locations of the switches, something I've overlooked or any other feedback I'd be very grateful.
Thanks in advance
--bob
   / LX279 PTO won't engage #2
:welcome: to TBN
Send a PM message to member "joecdeere" to check if he by chance has a copy of the service tech manual to send to you.. include an email address so if he does, and can, then you may get some help that way.
Maybe that switch again?
:welcome: to TBN
Thanks for the reply.
The switch checks out with an ohmmeter. The contacts open and close as expected.
I'll definitely send that message, thanks again
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
Ford 641 Workmaster (A50514)
Ford 641...
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2014 FREIGHTLINER CASCADIA DAY CAB (A51219)
2014 FREIGHTLINER...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
