LX178 Electrical System-Charging
   / LX178 Electrical System-Charging #21
OK I fixed my charging system today, it was a dirty plug/connection. I went through all of them unplugging and spraying with a spray lube. Nothing helped but when I got to the plugs on the back side of the key switch, I did the same procedure. The charging light is now off and the voltage to the battery if 13.7--ish, instead of 12.61. If you have charging issues check these connections.
Take care, I'm outta here/
   / LX178 Electrical System-Charging #22
OK I fixed my charging system today, it was a dirty plug/connection. ...
If you have charging issues check these connections. /
I think this is fairly common, I have an LX188 and the 6 pin connector has a bad connection.
It had an aftermarket VR with the longer set or wires.
The pin from 1 of the stator wires was totally welded to the nylon connector.
JD sells a kit # AM108848. Amazon gas a good photo. It comes with 2 extra connectors, but it costs ~$25.
BTW a new wiring harness from JD is about $300...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
2019 TRADEWINDS PUMPING UNIT TRAILER (A51406)
2019 TRADEWINDS...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2016 Chevrolet Tahoe SUV (A54815)
2016 Chevrolet...
2023 Club Car Carryall 700 Utility Cart (A54811)
2023 Club Car...
