LX Series Replaces B2650 and B3350
   / LX Series Replaces B2650 and B3350 #11
LX3310
lift/brkout: 769/1634: +48%/+65% vs the BX
For the increase in price (with FEL), to me it's not as big of improvement as I'd like. The old B was more affordable and much more capable (sans regen).
If the numbers are real-world-relatable the B's breakout was likely overboard for the tractor without a lot of counterweight, but wow would I love it! (Carrying capacity is probably a bit much for the stance, but back then perhaps the average person was more responsible.)
Maybe it's me, I just can't get excited about the LX FEL price vs performance, but the B3350 sure looked great until the regen issues showed up.
   / LX Series Replaces B2650 and B3350 #12
LX3310
The old "large" frame B series (ie: B2650/B3350) (vs the "small" frame B2601, etc) was "more affordable" (cost less) because it was produced 12+ years ago and stopped ~5+ years ago, LOL... It absolutely not NOT much more capable than the current LX series.
Not sure where you're getting your data, the FEL lift capacity on a LX3310 is:
  • Pivot pin max ht: 1067, Pivot pin @ 1.5m: 1324 (taken directly from Kubota's site)
https://www.kubotausa.com/products/tractors/compact/lx-series#compare
I've owned a BX25D and now own a LX3310.
Your 'Lift/breakout' numbers look more like the specs of their respective backhoes, not the FEL.
   / LX Series Replaces B2650 and B3350 #13
Click the model and it goes to the tractor data page I used.
I use the 500mm from the pin figures because when using a FEL I'm usually prying up rocks with the dirt, and they're typically near the bucket lip, so around 500mm ~ 20" from the pins.
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
1984 GROVE CRANE (A54607)
1984 GROVE CRANE...
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
2011 Kubota KX080-3 Midi Excavator (A55787)
2011 Kubota...
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
30pc. 16ft.x 3ft. White Metal Roof Panels (A55758)
30pc. 16ft.x 3ft...
