LX Series Replaces B2650 and B3350
   / LX Series Replaces B2650 and B3350 #1
SDT
SE Indiana
Multiple Fords and Kubotas
As expected, the new LX3310 is common rail injected. This should eliminate the regeneration issues that so plagued the B3350.
Cab models have LED work lights and optional air ride seat.
Both models offer single lever FEL hydraulic connections.
Quick connect front hitch similar to BX models available.
Though unclear from my information, it appears that a rear hydraulic remote is included.
R14 tires available.
HP remains same.
SDT
   / LX Series Replaces B2650 and B3350 #2
Thanks for the info.
Will it be similar in size to the B series or move up towards the L series? Any indication of price?
Given the problems with the B3350, I wonder how many early adopters there will be for the LX series.
   / LX Series Replaces B2650 and B3350 #3
Will this LX series offer a 26hp variant?
Are you aware if there are any changes to the B2601-1/B2301-1?
HP remains same.
SDT
The LX2610 replaces the B2650 and is similar in size and weight.
The LX3310 replaces the B3350 and is similar in size and weight.
HP of replacement models is identical to that of prior models.
I do not believe that prices have been announced but you can expect increases, especially for the common rail 3310 model.
SDT
   / LX Series Replaces B2650 and B3350 #5
Thank you sir.
SDT
   / LX Series Replaces B2650 and B3350 #7
This is an interesting post as I've been reading old threads looking to perhaps replace my BX with a B3350 for more FEL and PTO capacity...but, there was that thought in the back of my head that some older B models had regen problems...
Looking at the price of an LX in 2025 and the (as of 2025) small-ish increase in lifting ability...I'll be sticking with a BX.
   / LX Series Replaces B2650 and B3350 #8
'Smallish" increase in lift? It's a ~57% increase, right? So it's a significant increase by percentage.
good luck....
   / LX Series Replaces B2650 and B3350 #9
BX2370 vs B2601 (full at 500mm)
lift: 518 / 659 lbs : +27%
breakout: 992 / 1520 lbs : +53%
Older B3350:
lift/brkout: 827/1691: +60%/+157%
The B3350 has numbers matching its frame size increase (or at least what I was hoping for in a B).
   / LX Series Replaces B2650 and B3350 #10
In your post #7 above you compare a BX with a new LX and state there's only a small increase in FEL lift capacity.. That's not the case..
The old B3350 (discontinued 5+ years ago) is the predecessor to the LX line and is the (only) tractor which suffered from regen issues that have been resolved with the LX3310 and larger LX tractors.. There's no comparison between a BX and an LX in lift/performance..
good luck...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53472)
Michelin CARGOXBIB...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
