LX 277 will not run
   / LX 277 will not run #1
farmer598
john deere lx277
running just fine then started to sputter and died would not start and run with out choke being held on. Help
   / LX 277 will not run #2
Fuel issue. Check gas cap on tank for plugged vent hole, Check fuel filter, hoses for deterioration (dry and hard, cracking), finally fuel pickup in tank may be crapped up. Finally carb dirty (inlet valve, idle jet, main jet emulsion tube) and may need cleaning.
Also check the air box which contains the air filter (may also have and outer filter known as a pre-filter) may be dirty.
   / LX 277 will not run #3
Sounds like you ran out of gas -------------
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
550 Tubes Grease Cartridges (A53117)
550 Tubes Grease...
2019 JOHN DEERE Z960M ZERO TURN LAWN MOWER (A51247)
2019 JOHN DEERE...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
Reserved (A53117)
Reserved (A53117)
