LX 255 charging issue
/ LX 255 charging issue #1
Clyde the Pointer
Heath, OH
MF 235
Fine folks of the forum:
Data JD LX 255 Kohler 15 hp motor.
Dead in water the other day while mowing. New fuel pump and electric clutch last year.
Today replaced the fuel lines and filter. Ran for 5 mins while test cutting and died again.
Will start, but dies when you: 1) take off brake (must be applied to start) or 2) engage PTO.
So I am thinking battery and buy a new one, no change. Battery light is on at the dash. Seat "sit on and start" thing is jumped out. I tilted up the bodywork this morning to get to fuel lines and to my knowledge did not disturb anything.
I found a brake switch on ebay : Interlock Switch Fits Ariens Craftsman Sears Exmark MTD John Deere Murray More | eBay
and this circuit board: John Deere Key Switch Ignition Module GT225 GX325 X475 AM132500 AM131841 | eBay
I don't mind dumping another $100 bucks into this thing if it will work. I am not a very good mechanic, however can do some stuff.
Whatchoo think?
Thanks in advance.
/ LX 255 charging issue #2
I'm thinking a safety switch malfunction... maybe a wire came loose?
Good suggestion. I cleaned the spade terminals of the corrosion, used dielectric grease, and it started/ran/mowed. Battery light still on.
KING 7 SHANK CHISEL PLOW (A63290)
KING 7 SHANK...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
2016 John Deere 1795 Planter (A63109)
2016 John Deere...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
TONUTTI 8 WHEEL V-RAKE (A63290)
TONUTTI 8 WHEEL...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
