LX 188
   / LX 188 #1
Casinojim
LX188 John Deere
Hello all . I've had a lX 186 for years great mower and now I just got a lX 188. I cut grass 3 times but last time I mowed it started bogging down but ran better with pto off. then it died. fuel pump is working carb has gas. Put new plugs in .j just cranks , it will run on starter fluid tell it burns it out any clues what the problem is
   / LX 188 #2
Welcome to TBN. It would be a good thing to know that the little solenoid @ the carburetor bowl is working and the fuel is clean happy gasoline rather than having water or diesel in it.
   / LX 188
Was mowing when it died has good gas seames 2 be flooding over flow on top of carb driping gas
   / LX 188 #4
These mechanical fuel pumps can move a fair amount of fuel. So should the carb be letting fuel through, it doesn't take long to flood it out. Of course, the pump can have issues as well. Any fuel in the oil?
   / LX 188 #5
Is the lX 188 new or just new to you ?
From your description, it sounds like you may have dirt in the float needle or a stuck float.
LOT LOCATIONS (A52141)
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
