LX 178 FD440V Carburetor question
   / LX 178 FD440V Carburetor question #1
mikepsl
LX 178 & STX 38
Hi all,
I am a new owner of a LX 178 with the Kawasaki Fd440V. The machine was in a really bad shape, but I like the tractor overall and started rebuilding it on a tight budget.
The carburetor o ring of the float bowl is damaged and needs to be replaced. At the same time I saw that the top part of the float bowl is corroded. So I looked up the spare parts and saw that those parts a pretty expensive.
However, I found this part on Ebay. Item number 323820832579 ( Can't post links in my first 3 posts )
It looks almost identically to the one installed and I was wondering if someone had experience with those carburetors and know if they will fit my machine. I emailed the seller, but they couldn't really tell me.
Looking forward to your answers,
Mike
   / LX 178 FD440V Carburetor question #2
No. This fits a walk mower with a FC150 model engine. How bad is the corrosion? They are aluminum and some Scotchbrite will clean it up if it isn't a leaker. You can buy the o rings separate at Deere. Welcome to TBN BTW!
Hmm, I am stubborn enough and bought it. According to Jacksmallenging.com the float bowl and the o ring have the same partsnumber. I give it a try and see if they fit.
Mike
   / LX 178 FD440V Carburetor question #4
Pretty clever. It would be a cheap way to get a bowl. Keep us in the loop.
Got the carburetor today. The float bowl is minimal larger, with a little force I would be able to fit it in. However, the "O-Ring" which is not really an O ring, it´s squared fits well and I could just use that with the old float bowl and it works. Once I am cleaning the carburetor next time, I will see if the complete carburetor fits. I would guess yes.
   / LX 178 FD440V Carburetor question #6
Even though the chamber was the same, the carb from your engine and a 5 HP engine will be considerably different if that is what you mean. Unless the seller didn't know what he had. . .
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
JOHN DEERE 54D LOT NUMBER 160 (A53084)
JOHN DEERE 54D LOT...
2020 JOHN DEERE 333G SKID STEER (A51246)
2020 JOHN DEERE...
2023 LMC M30018 LOT NUMBER 207 (A53084)
2023 LMC M30018...
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
2022 CATERPILLAR 317 EXCAVATOR (A51246)
2022 CATERPILLAR...
