LW8 backhoe hydraulic hose o ring question
   / LW8 backhoe hydraulic hose o ring question #1
DonRina
Vancouver Island
Jinma 354
Just wondering what type of o ring the hydraulic hoses take for sealing on my LW8? The description is o ring but is that true or are they some type of flat rubberized seal? Any idea of the sizes used on the backhoe and I guess the loader as well. I’m just replacing the lines outer spiral wrap as mine are all sun rotted out and it might be a lot easier to pull the lines off the valve block instead of threading it in situ. Did wrap the easier ones but lots of them are a pig to get at.
Thanks,
Don B
   / LW8 backhoe hydraulic hose o ring question #2
The O-rings for the ORFS fittings are 6 mm nitrile, although silicone would be preferred.
I guess that’s 6mm inside diameter then? Couldn’t seem to find these listed on the Jimna part suppliers web sites. Is it possibly something a hydraulic shop would have?
   / LW8 backhoe hydraulic hose o ring question #4
I bought an O-ring set at Harbor Freight. Worked very well. You can also get them on Amazon and NAPA. But yes, a hydraulic shop might have them.
That’s great. I thought they were they were the NBR Metal Bonded Sealing Washer type.​
   / LW8 backhoe hydraulic hose o ring question #6
O-ring Face Seal (ORFS) fittings do not require bonded washers. Banjo bolt fittings do.
SLOWLY learning hydraulics. Thanks for your help. I ordered the o rings in silicon.
Fort DMD 2050 Disc mower (A49251)
Fort DMD 2050 Disc...
Wall Mount AC Unit (A46687)
Wall Mount AC Unit...
More info coming soon! (A48081)
More info coming...
2025 Chery 10ft 15 Drawer 2 Cabinet Workbench (A46687)
2025 Chery 10ft 15...
Used 40' Single End Door Container (A47371)
Used 40' Single...
TPM 18K Mini Excavator (A49251)
TPM 18K Mini...
