Backhoe LW 7 Jinma backhoe that never works
   / LW 7 Jinma backhoe that never works #1
buffalobill14108
newfane ny
jinma 354
Has anyone ever replaced their 6 spool control valve set up on one of these miserable units, and if so what kind, how much and where can I get one. Thanks, Bill :eek:
   / LW 7 Jinma backhoe that never works #2
6 SPOOL 16 GPM WALVOIL JOYSTICK BACKHOE HYD VALVE
$450
But I got to ask... why cant you get the existing to work? Hydraulic spools are fairly simple. If a rod was machined wrong its easy to replace that individual spool vs the entire 6 valve control.
fyi there is a hydraulics specific forum were you might find eyes that are more knowledgeable in hydraulics specificity.
   / LW 7 Jinma backhoe that never works #3
$450
ditto / my thoughts as well
hydrualic forum more likely get info you want, and describing what is going on with the unit.
I had a mechanic pull apart the relief valve and he found the inside part with the o-ring to fit much too tight. He hoaned and replaced twice, how would work for an hour and quit. Met a man who delt in these units, he got out as people kept coming back wanting refunds. So enough is enough. The cylinders look sound and so does the steel. Been battling this POS all summer, I need to get digging. I took your advice and bought a 16 gpm unit from surplus.
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
1992 Kenworth T800 Semi (A50514)
1992 Kenworth T800...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
Wolverine Mini Skid Steer Auger Drive & Bit (A50514)
Wolverine Mini...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
2015 GMC Acadia SLT1 SUV (A50324)
2015 GMC Acadia...
