Backhoe LW 7 Jinma backhoe that never works
   / LW 7 Jinma backhoe that never works #1
buffalobill14108
newfane ny
jinma 354
Has anyone ever replaced their 6 spool control valve set up on one of these miserable units, and if so what kind, how much and where can I get one. Thanks, Bill :eek:
   / LW 7 Jinma backhoe that never works #2
6 SPOOL 16 GPM WALVOIL JOYSTICK BACKHOE HYD VALVE
$450
But I got to ask... why cant you get the existing to work? Hydraulic spools are fairly simple. If a rod was machined wrong its easy to replace that individual spool vs the entire 6 valve control.
fyi there is a hydraulics specific forum were you might find eyes that are more knowledgeable in hydraulics specificity.
   / LW 7 Jinma backhoe that never works #3
$450
ditto / my thoughts as well
hydrualic forum more likely get info you want, and describing what is going on with the unit.
I had a mechanic pull apart the relief valve and he found the inside part with the o-ring to fit much too tight. He hoaned and replaced twice, how would work for an hour and quit. Met a man who delt in these units, he got out as people kept coming back wanting refunds. So enough is enough. The cylinders look sound and so does the steel. Been battling this POS all summer, I need to get digging. I took your advice and bought a 16 gpm unit from surplus.
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
UNUSED MOWERKING QUICK ATTACH BRUSH CUTTER (A51244)
UNUSED MOWERKING...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
