LVB25546 Forward Light Kit on 3720
   / LVB25546 Forward Light Kit on 3720 #1
platinumits
John Deere 3320
I got the ROPS brush guard kit and the Forward Light Kit LVB25546 for my new 3720 manufactured in 2012. Wondering if anyone else has this problem with installation.
The kit comes with a splitter harness using black and purple wires and is supposed to mate to same color harness on the bottom of the ROPS. My 3720 harness has 3 wires, black, grey and white and the male / female connectors dont match the 3720 genders. Not sure how to proceed.
The other thing is that the JD install says to route it through the ROPS and have the wires come out the bottom. Good luck, even with my electric fish sticks i cant even come close to running the wires down the inside of the ROPS.
Any help is appreciated.
   / LVB25546 Forward Light Kit on 3720 #2
Are there any current wires runnig thru the ROPS? If so, can you use them to pull a string/wire thru? If you do that, remember to plan a way to pull the original wires back, extra string/wire pulled thru.
I would ask Service at the Dealer if they have to change the connector(s) when they have done the install. They surely have done this before and solved the problem.
No luck with the dealer, they couldnt figure it out without the tractor there. The provided harness LVA10595 doesnt have the right genders on it to make it work. I can jerry rig it up so all but one function works, but then the display reads ERR 65 when I try hazards+Front lights. I need some gender changers or a different harness. Anyone?
2020 Big Tex 22GN25T5 30' Gooseneck Trailer, VIN: 16V6X2528L6050344, Tandem Axle, Wood Deck, Bad (A59076)
2020 Big Tex...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2026 Hillcrest Dump Trailer (A56858)
2026 Hillcrest...
