Lubricating the Pedal Shaft
   / Lubricating the Pedal Shaft #1
Mosey
Veteran Member
Conifer, Colorado
2000 New Holland TC29D with 7308 FEL, and top & tilt. 1950 John Deere B. 1940 Farmall A.
I can't find grease zerk #20, which they call the "Pedal Shaft". I took off the left cover under the dash and looked in there, but didn't see anything. Is it under the tractor? I thought maybe they meant the Clutch Pedal shaft, but that's #9 in the chart, or the Brake Pedal shaft, but that's #18 in the chart, or the HST Pedal Pivot, but that's #23 in the chart. So, I'm stumped on this one. I have attached the diagram.
   / Lubricating the Pedal Shaft #2
If I'm remembering correctly my TC18 had two zerks for the brakes. Follow the rod from the brake pedal under the tractor towards the left side. Good luck.
hazmat - Thanks, I found it. There's also 2 zerks on the clutch pedal rod, one under the pedal and one towards the inside of the tractor (to the right).
2012 Volvo XC70 Wagon Sedan (A50324)
2012 Volvo XC70...
2013 Ford Explorer XLT SUV (A50324)
2013 Ford Explorer...
JMR 40" Mini Root Grapple (A50121)
JMR 40" Mini Root...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
2021 John Deere 333G Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
Case-IH 370 Steiger (A50120)
Case-IH 370...
