lubricating oils
/ lubricating oils #1
shrekbelly
guys,
i need to start a regular oiling and greasing schedule on my bx. have also got confusing advice on what to use.
what is the concensus on good oils, for my new oiling can/pump. as always, any input is greatly appreciated . . . . to old and broken down, ought to know better . . . hookopotomous regards, shrekbelly
/ lubricating oils #4
gwdixon, steered you right, follow your manual for greasing all points and change your engine oil at least once a year even if your hours are low. I did this on my BX23 TLB and never had a issue. You may want to use synthetics oils if you live in colder areas for the winter, It makes starts a bit easier on engine.
DevilDog
/ lubricating oils #5
For engine oil I have used Rotella, Kubota and New Holland, SUDT for the transmission; lithium base in grease gun. I use mine year round, so I go by hours, but if you don't put enough hours, I would change engine oil yearly anyway unless stored in a heated place. The BX is really simple to service.
/ lubricating oils
sorry i'm such a dreadful communicator, i was/am curious if there's a preferred brand on 3 in 1 lubricant (i have my greases & engine oils lined up).
thanks, shrekbelly
/ lubricating oils #8
I use Breakfree CLP.
/ lubricating oils #9
@TripleR: I used to use a gun oil called CLP that came in jugs and I don't recall a brand name on it....had teflon particles in it. Is that the stuff you use?
/ lubricating oils #11
I got turned on to fluid film by someone in this post,( sorry I don't remember who) to free up my 3pt hitch "eye balls" and I was really impressed with the performance it did amazing things.......until it got cold then it Turns thick and harder to move parts. unless something else happened between plowings, I have to assume it is the cold. It is nice to have a candy smell on you after hooking up 3pt hitch instead of the diesel smell of "PB penetrating oil"...
/ lubricating oils #12
boxers versus briefs. use whatever you are comfortable with, just change it regularly.
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2022 21ft Scout 210 Dorado Boat with 2011 18ft Magic S/A Boat Trailer (A64557)
2022 21ft Scout...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
PORTA POTTY (A67714)
2024 Kubota SVL97-2 (A64911)
2024 Kubota...
Deere 317G (A64911)
Deere 317G (A64911)
