Lubricants for 1948 Ferguson TE-20
   / Lubricants for 1948 Ferguson TE-20 #1
Batman50615
Center, MO
Ferguson 20
Have a 1948 Ferguson TE-20. What are the correct lubricants for the following:
Transmisson/Gear Box
Hydraulic Reservoir
Steering Box
   / Lubricants for 1948 Ferguson TE-20 #2
if the te20 is liek the 9n, the trans, hyds, and rear end are common sump, and probably originally specced a 90w mineral gear oil.. which wil be similar to a 90w gl1 or gl3 oil today.. though an 80w90 gl4/5 that carries the mt1 rating and states that it is yellow metal safe would be fine too. alternately.. a utf meeding the m2c134 spec would work without damage.. though if you have weepy axle, tranny, pyo seals and a non rebuilt 3pt lift.. you may get leaks and weaker lift.
ont he steering box.. if it is not open to the tranny as the early fords are, then i would lube with 0 or 00ep grease.. though it's manual probably called gor a similar 90w mineral gear oil.. or sae 50w engine oil.
if the sump is closed and the sector seals don't leak ;).. gear oil is fine.. if open sump.. nothing to do... if sector seals weep.. 00ep grease.. :)
   / Lubricants for 1948 Ferguson TE-20 #3
Tranny/hydraulics are common sumps. The Spec is GL-1 SAE 80 for temps below 50F and SAE 90 above 50F. It's still available at NAPA. You can also use the latest Massey Ferguson transhydraulic fluuid I thinks its' 1129 or something or any UTF that meets the Massey specs. Steering box uses the same lume as the trannny and hydraulics.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
1973 FORD 9000 TANDEM AXLE DUMP TRUCK (A52576)
1973 FORD 9000...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
JOHN DEERE 7210R LOT NUMBER 263 (A53084)
JOHN DEERE 7210R...
1271 (A50490)
1271 (A50490)
