Rear Blade Lube Your Shaft - It's Fun and It's Easy
   / Lube Your Shaft - It's Fun and It's Easy #1
BIG DOOLEY
Platinum Member
MICHIGAN
JOHN DEERE 2320
In less than 10 minutes you can drill out the hole(s) tap some threads and install the zerk fittings.
This is the rear blade for my tractor.
I decided to lubricate the pivot for the rear blade and the cylinder clevis pins.
I drill a 1/16" pilot hole and then a #3 drill deep enough to tap with a 1/4"-28 tap.
The cylinder clevis pin received a grease channel all the way around the pin.
The grinder was held in the vise by the grinder handle and I rotated the pin cutting a groove.
It just that easy.
Tom
   / Lube Your Shaft - It's Fun and It's Easy #2
grease.... what a stupid idea!
   / Lube Your Shaft - It's Fun and It's Easy #3
If you just drill it to 15/64 you can just thread in the zert no need to cut the threads unless it is a hardened material.
Grease the very best thing you can do for any machine.
Before I start any machine, I repeat oil, air, water, PS fluid, and turning devices if you have been working on it. The PS fluid includes all the hydraulic oils, transmission fluids gear oils, and did I grease it.
Just a mental exercise to be sure I did not forget something.
   / Lube Your Shaft - It's Fun and It's Easy #4
Interesting. I just got a new back blade and noticed that it has no Zerk, I'll have to add one!
   / Lube Your Shaft - It's Fun and It's Easy #5
Is it supposed to be green like that?? :laughing::laughing:
   / Lube Your Shaft - It's Fun and It's Easy #6
This sounds like a fun project by the fire on a frigid weekend sometime. :thumbsup:
   / Lube Your Shaft - It's Fun and It's Easy #7
What is the green chain hanging on the right side in the last picture?
   / Lube Your Shaft - It's Fun and It's Easy #8
It looks like the pin that holds the blade in position.
   / Lube Your Shaft - It's Fun and It's Easy #9
Dooley you are **** to a fault:thumbsup: . Seriously , all your projects turn out nice and all the details are done . It is much easier to do all the details now isn't it . Look forward to future posts , Kevin .
   / Lube Your Shaft - It's Fun and It's Easy #10
Looks good to me. A little grease never hurt anything.
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
2842 (A54757)
2842 (A54757)
202477 (A54757)
202477 (A54757)
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
2000 Chevrolet C2500 Ext. Cab Pickup Truck (A55852)
2000 Chevrolet...
