lub points
   / lub points #1
jimwillis
i have a slt 1550 i know that the wheels and axle have lub points and the spindels for the mowing deck. are the lub points for the spindels below the deck or on the top. i assume they are some more points. can some one tell me where they are
thanks
   / lub points #2
the spindle fittings are under the deck. I grease mine when i have the blades off for touch up sharpening.
   / lub points #3
There is also a fitting on top of the idler pulley bracket at the pivot point.
When greasing the spindle bearings there is a weep hole in the center of the housing. I have an air operated grease gun and pumped a few oz of grease out this hole while watching for it to come out the top or bottom on the first one.
It is best to remove the deck and turn over to grease. It's tricky to get the belt back on. There is a square hole in the idler bracket that a 3/8" ratchet/breaker bar fits in so you can pull the pulley back to put the belt back on. You just have to stand on your head to do this!
2025 Epic Electric Golf Cart (A51694)
2025 Epic Electric...
2018 CATERPILLAR 950GC WHEEL LOADER (A52705)
2018 CATERPILLAR...
1838 (A51248)
1838 (A51248)
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
