LTX1046KW grease points????
   / LTX1046KW grease points???? #1
whitearrow
philadelphia,ms
john deere 5203
Good morn fellas. I've got said cub and I've found 4 grease zerks. 2 on each end of the axle and 1 per front wheel. I got under it and looked for a zerk on the spindle but did not see any. Is there any that I'm missing?
Thanks,
Big Ed
Thanks and I've seen that but I don't know whether they put diff spindles on the kw with the kawi engines but mine doesn't have a zerk there.
   / LTX1046KW grease points???? #4
Some of the spindles on Cubs have sealed bearings and do not have zerks. Some Cub spindles have sealed bearings and DO have zerks that are useless. Some Cubs have spindles that have zerks that are way up inside the center of the spindle where it is impossible to get to without removing the deck and flipping it upside down. I think it's all a matter of what Chinese spindle supplier had parts on the shelf at MTD when they built your mower.
Mine has the "impossible to get to" zerks. They get greased maybe every other season or whenever the deck has to come off for something. If I never have to remove the deck, I'll just run the spindles to failure.
2019 JLG 2632ES 26ft Electric Scissor Lift (A55787)
2019 JLG 2632ES...
2014 Ford F-150 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
2017 Nissan NV200 Cargo Van (A55788)
2017 Nissan NV200...
2004 Ford F-250 (A53422)
2004 Ford F-250...
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55301)
2008 Ford F-250...
