LT2166 Cruise Control Linkage
   / LT2166 Cruise Control Linkage #1
wknopf
Saint Charles, IL
Cub Cadet LT2166
Just got a new Cub Cadet 2166. It dropped into cruise control while mowing and the control lever has no effect, it feels like it is disconnected. Silly question - how do I access the linkage? Do I bend the tabs on the panel in front of the seat and remove it or do I need to access it from underneath?
   / LT2166 Cruise Control Linkage #2
wknopf,
Since no one is replying I will try to help. I am not intimately familiar with your EXACT model, but on the ones that I've seen, the cruise lever simply is a bell crank whose pivot center goes through the inner, rear fender well. The other lever from the bell crank that is inboard of the fenderwell actuates a rod that goes to the hydrostatic pedals.
Pulling off the escutcheon plate around the lever will accomplish nothing.
You will have to look underneath. I would start by seeing if the linkage is connected on the bell crank at the rear inboard and the bell crank on the pedal lever which is inboard of the frame above the deck.
Hope this helps,
Doc
2015 Ford F550 Bucket Truck - Versalift VST47 Boom - Powerstroke Diesel - Automatic - 4X4 (A55302)
2015 Ford F550...
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
2020 FREIGHTLINER M2 SINGLE AXLE BOX TRUCK (A56129)
2020 FREIGHTLINER...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
23222 (A50323)
23222 (A50323)
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
