LT180 ?
/ LT180 ? #1
buckbros
Maryland
john deere LT180, John Deere GT235, 1950 Case Vac, 2 Gravely L Models
Does anyone have a wiring diagram that shows the wires to the RIO switch and where they go to? My switch only had two wires going to it. Every diagram I found is just about as clear as mud to me as my electrical expertise is next to nothing.
/ LT180 ? #2
Well if I only knew what a "RIO" switch is, perhaps I could help.
Richard
/ LT180 ?
Richard
Here it is, can you help?
/ LT180 ? #5
The LT series has a plunger type switch RH side of the transaxle which is activated when you push the reverse pedal.
/ LT180 ?
When backing up the engine stalls momentarily. Could this switch be the problem. I know the RIO switch on the dash is not the problem.
County Line 3Pt Bale Spear (A66408)
County Line 3Pt...
Bush Hog 18ft. Disc (A65640)
Bush Hog 18ft...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
Allmand 8KW Light Tower (A64194)
Allmand 8KW Light...
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
