LT160 starts easily, but quits when brake pedal is released
   / LT160 starts easily, but quits when brake pedal is released #1
02chuck1
Farmington, Ca
Kubota L3200. John Deere LT160
MY LT160 is being a PITA. It will start right up with the brake pedal pushed down, but when you release the brake pedal it dies.
I checked the brake pedal switch connection, checked the back of the ignition switch. Had no issues before this.
Any ideas on what could be the issue?
Thanks
Chuck
   / LT160 starts easily, but quits when brake pedal is released #2
Seat safety switch is the problem.
   / LT160 starts easily, but quits when brake pedal is released #3
Or possibly the PTO switch is on.. or system thinks it is on.
   / LT160 starts easily, but quits when brake pedal is released #4
It’s a manual PTO engagement. You’ll have to look under the dash a little bit. Watch the lever where it makes contact to the switch. The seat switches cause issues as they get older as well. 😊
Seat Safety Switch was the issue. I had used a zip tie to bypass the switch and it had slipped and the plunger
had returned to the no driver position and since it was not where it belonged it was not being depressed when sitting on it.
Thank Guys
Chuck
JOHN DEERE 648R LOT NUMBER 108 (A53084)
JOHN DEERE 648R...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53472)
2023 New Holland...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
LMC LOT NUMBER 140 (A53084)
LMC LOT NUMBER 140...
