LT160 starts easily, but quits when brake pedal is released
   / LT160 starts easily, but quits when brake pedal is released #1
02chuck1
Farmington, Ca
Kubota L3200. John Deere LT160
MY LT160 is being a PITA. It will start right up with the brake pedal pushed down, but when you release the brake pedal it dies.
I checked the brake pedal switch connection, checked the back of the ignition switch. Had no issues before this.
Any ideas on what could be the issue?
Chuck
   / LT160 starts easily, but quits when brake pedal is released #2
Seat safety switch is the problem.
   / LT160 starts easily, but quits when brake pedal is released #3
Or possibly the PTO switch is on.. or system thinks it is on.
   / LT160 starts easily, but quits when brake pedal is released #4
It’s a manual PTO engagement. You’ll have to look under the dash a little bit. Watch the lever where it makes contact to the switch. The seat switches cause issues as they get older as well. 😊
Seat Safety Switch was the issue. I had used a zip tie to bypass the switch and it had slipped and the plunger
had returned to the no driver position and since it was not where it belonged it was not being depressed when sitting on it.
Thank Guys
Chuck
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2018 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2018 Ford F-450...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
