LT1050 Oil Change HELP !!!
   / LT1050 Oil Change HELP !!! #1
hdsanders
I have just changed the oil per the manual; however, the mower will not start and the CHG OIL lidht is still blinking.
Any help woul dbe appreciated!!!
   / LT1050 Oil Change HELP !!! #2
The change oil indicator will flash for a while after the hour meter reaches the milestone that turned it on. The below is from the LT1050 manual
The LCD will alternately flash the recorded hours and CHG and OIL for five minutes after every 50 hrs of recorded operation. The maintenance interval lasts for two hours(from 50-52, 100-102, 150-152, etc). The LCD will flash as described above for five minutes every time the tractor engine has been started during the maintenance interval.
By not starting do you mean it doesn't turn over or does it turn and not start?
   / LT1050 Oil Change HELP !!! #3
Is the oil level full?? This engine may have the protection that it will not start if not full with oil. Also,check to make sure you didn`t (by mistake) pull any wires loose while changing the oil.
   / LT1050 Oil Change HELP !!! #4
And make sure you are in the seat, with the parking brake set and the PTO off to satisfy the ignition circuit.
Joel
   / LT1050 Oil Change HELP !!! #5
Did you disconnect spark plug wire/s when you changed oil as a safety measure?
JOHN DEERE LAWN MOWER (A55758)
JOHN DEERE LAWN...
Galvanized Livestock Gate (A55301)
Galvanized...
2009 RoadTec RX500 Asphalt Cold Planer Milling Machine (A55787)
2009 RoadTec RX500...
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
