LT1050 leaking fluid
/ LT1050 leaking fluid #1
1scotty4
Yesterday while blowing snow the electric pto would disengage. If I turned the switch off and back on it would work again. Then I noticed spots of fluid on the drive way. I put it back in the garage and this morning checked to see if there was fluid on the garage floor. There was none. I check the engine oil level and it was full of oil. I could smell what seemed like transmission fluid while I was blowing snow. Anyone have any ideas what is going on? The LT 1050 is about 4 years old.
Thanks,
Jerry
/ LT1050 leaking fluid #2
the tranny in your tractor - even tho a factory sealed unit - contains a motor oil, not hydraulic fliud. Unless you have a custom hydraulic setup on your snowblower of some type, would suspect one of your vehicles being parked on that driveway is the source... MHO.
10ft Fork Extensions (A66734)
10ft Fork...
2016 Kia Rio Sedan (A66738)
2016 Kia Rio Sedan...
2015 Mack GU713 T/A Day Cab Truck Tractor (A64556)
2015 Mack GU713...
PANTHER T14R TRACKED DUMPER (A65056)
PANTHER T14R...
2022 CATERPILLAR 259D3 SKID STEER (A65056)
2022 CATERPILLAR...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
