LT1046 drive belt
/ LT1046 drive belt #1
Ludakris
Cub Cadet LT1046
so, I snapped the drive belt the other day. a twig got wedged in between the belt and pulley...
anyways, got the new belt.. took the deck off, looked up... Huh....
How do I go about putting the new one on? does the PTO clutch come off? is it spring loaded or anything?
I dont have air tools.. so I am not sure about being able to get the PTO clutch off if necessary..
any other, easy ways to replace it?
thanks..
/ LT1046 drive belt
Nobody has changed a drive belt?
new question, is the PTO clutch spring loaded? there is a brace that keeps it in place, if i remove this, is there tension on it that I have to worry about?
/ LT1046 drive belt #3
There is no tension on the clutch, you do have to remove the brace.
/ LT1046 drive belt #4
I've never replaced a drive belt on a 1046 before, but i doubt there is much difference between it and the belt drive system on my SLT 1554. I had to removed the PTO clutch (which was not very difficult, only one bolt holding it on) the clutch will slide straight down to expose the the belt pulley on your motor output shaft. The shaft is keyed to accept the PTO clutch, the PTO can only go on the shaft one way. The hardest part was routing the belt around the large pulley on the drive axle at the rear of the tractor. Be sure you re-route the belt properly so the belt tensioner does its job. It is not a difficult job to replace it, maybe a 45 minute job if you are taking your time.
/ LT1046 drive belt
Great, Thanks guys.
Skid Steer Bale Spear (A65640)
Skid Steer Bale...
24in excavator tooth bucket (A61307)
24in excavator...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
