LT1046 drive belt
   / LT1046 drive belt #1
Ludakris
Cub Cadet LT1046
so, I snapped the drive belt the other day. a twig got wedged in between the belt and pulley...
anyways, got the new belt.. took the deck off, looked up... Huh....
How do I go about putting the new one on? does the PTO clutch come off? is it spring loaded or anything?
I dont have air tools.. so I am not sure about being able to get the PTO clutch off if necessary..
any other, easy ways to replace it?
thanks..
   / LT1046 drive belt
Nobody has changed a drive belt?
new question, is the PTO clutch spring loaded? there is a brace that keeps it in place, if i remove this, is there tension on it that I have to worry about?
   / LT1046 drive belt #3
There is no tension on the clutch, you do have to remove the brace.
   / LT1046 drive belt #4
I've never replaced a drive belt on a 1046 before, but i doubt there is much difference between it and the belt drive system on my SLT 1554. I had to removed the PTO clutch (which was not very difficult, only one bolt holding it on) the clutch will slide straight down to expose the the belt pulley on your motor output shaft. The shaft is keyed to accept the PTO clutch, the PTO can only go on the shaft one way. The hardest part was routing the belt around the large pulley on the drive axle at the rear of the tractor. Be sure you re-route the belt properly so the belt tensioner does its job. It is not a difficult job to replace it, maybe a 45 minute job if you are taking your time.
   / LT1046 drive belt
Great, Thanks guys.
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
2012 Benlee TABM40 Semi Roll-off 2 Axle Trailer (TITLE) (A50774)
2012 Benlee TABM40...
AGT QH12 Mini Excavator (A50322)
AGT QH12 Mini...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
