LT1000 axle lube
/ LT1000 axle lube #1
studhauler
Cub 125, Toro 223D
It has probably been asked before, but i couldn't find it. What to use as lube in a standard transmission LT1000 lawn tractor? And how much of it? Lawn tractor model number 91727910
The stuff I am sucking out looks like a metallic goo. I got 1/2 pint out, but that is not saying it was at the proper level. I bought this mower last year, it is a low time, severely neglected rider. 20 hp, manual trans, 42" cut. It will not be used in the winter.
Thanks
/ LT1000 axle lube
The model number for the transaxle on my rider is MST-206-545c which is made by Peerless.
From the Tecumseh Technician’s Handbook, copy write 2002, chapter 1, page 1. “The MST Series The MST (Manual Shift Transaxle) is a sealed unit which uses 16 oz. (473 ml) of 80W90 gear lube (part #730229B). The MST series is available with up to 6 speeds forward and one reverse and has a contoured case and cover.”
There is a fill plug in the top of the transaxle almost under the driven pulley. I suck out the old oil with a manual vacuum pump, other take the transaxle out, then turn it upside-down. I put the gear lube in via a tube attached to the funnel top on most gear lube bottles, then as the bottle is positioned upside down, I cut a slot in the bottom of the bottle with a utility knife, so that it was not air locked. It took maybe about an hour for it to drain into the axle housing.
Wolverine RPR-12-72W Skid Steer Ripper  (A62679)
Wolverine...
DMI Tiger-Mate Field Cultivator Hitch (A65640)
DMI Tiger-Mate...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
Pallet Racking (A65640)
Pallet Racking...
Allis Chalmers 1200 Field Cultivator (A66408)
Allis Chalmers...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
