LT1000 axle lube
   / LT1000 axle lube #1
studhauler
Cub 125, Toro 223D
It has probably been asked before, but i couldn't find it. What to use as lube in a standard transmission LT1000 lawn tractor? And how much of it? Lawn tractor model number 91727910
The stuff I am sucking out looks like a metallic goo. I got 1/2 pint out, but that is not saying it was at the proper level. I bought this mower last year, it is a low time, severely neglected rider. 20 hp, manual trans, 42" cut. It will not be used in the winter.
   / LT1000 axle lube
The model number for the transaxle on my rider is MST-206-545c which is made by Peerless.
From the Tecumseh Technician’s Handbook, copy write 2002, chapter 1, page 1. “The MST Series The MST (Manual Shift Transaxle) is a sealed unit which uses 16 oz. (473 ml) of 80W90 gear lube (part #730229B). The MST series is available with up to 6 speeds forward and one reverse and has a contoured case and cover.”
There is a fill plug in the top of the transaxle almost under the driven pulley. I suck out the old oil with a manual vacuum pump, other take the transaxle out, then turn it upside-down. I put the gear lube in via a tube attached to the funnel top on most gear lube bottles, then as the bottle is positioned upside down, I cut a slot in the bottom of the bottle with a utility knife, so that it was not air locked. It took maybe about an hour for it to drain into the axle housing.
2019 Ford Explorer SUV (A51694)
2019 Ford Explorer...
UNUSED RAYTREE RMDM725-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
ECHO PB-580 H/T GAS BACKPACK BLOWER (A51248)
ECHO PB-580 H/T...
2015 Dodge Journey SUV (A51694)
2015 Dodge Journey...
