LT 2042 still "creeps" after letting off the forward pedal
   / LT 2042 still "creeps" after letting off the forward pedal #1
bluegold
Port Saint Lucie FL
Cu Cadet LT2042
My LT 2042 which has about 300 hours slows down but not fast enough when I let up on either of the forward or reverse pedal. I tried lubricating all the linkage and it did seem help a little but still not enough.
Does anyone have any ideas on what would cause this and how to correct it??
Thanks for any input.
bluegold
   / LT 2042 still "creeps" after letting off the forward pedal #2
Assuming you have an HST transmission, and as this problem is occurring in forward and reverse, the HST neutral switch requires a little adjustment. On my Kubtoa B3300SU the switch was under the tractor, subject to brush hitting it.
   / LT 2042 still "creeps" after letting off the forward pedal #3
There's a neutral adjustment procedure in the owners manual. If you don't have the manual you can download it here after entering the model number which I believe is 13A-286G710 for the LT2042.
You might also wan check to make sure the spring is still attached that returns the linkage to neutral.
Thank you for the replies. I will check both out and repost the results.
   / LT 2042 still "creeps" after letting off the forward pedal #5
I have a 2165 that I bought used and it creeped in neutral after all the adjustments. When it came time to change the hydraulic oil I used the Cub oil and filter, solved the creeping immediately. I don't know what oil was in it before.
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2015 Ford F-150 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
