LT 1554 PTO not engaging
   / LT 1554 PTO not engaging #1
shawnkaan
Cub Cadet GT1554
Hello,
I have 12 hours on this tractor and today the PTO just stopped engaging. I pushed the knob back in and pulled it back out it would turn on then shut off. Now it doesnt turn on. Any idea's? I tried to start the PTO in reverse as well since I read some other posts that say it may be the reverse wire. Mine seems intact down to the brakes. Any help would be great. Thank You
   / LT 1554 PTO not engaging #2
Check the fuse for the PTO, then check that the seat safety switch for the PTO isn't tripped. I don't know if it's a separate switch from the engine cut-off, but it might be.
   / LT 1554 PTO not engaging #3
I believe there is a Relay switch under the dash that could be faulty as well.. If it's new I'd take it right back to where you bought it and bend an ear or two.. :goodl:
2023 Yamaha VXC Wave Runner Jet Ski (A55758)
2023 Yamaha VXC...
2015 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2015 Ford F-350...
Hydro Thumb Clamp (A53316)
Hydro Thumb Clamp...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
