LT 155 Kohler 15hp wiring Qs
   / LT 155 Kohler 15hp wiring Qs #1
canucklehead
frozen Canada
1979 Ford 1500, Toro 455D 10' mower w/ Renault diesel,
I have a Kohler 15 HP engine that came out of an LT155. I am hoping to put it in my Kubota T1560. The Kubota had a Kawasaki FC420V engine. The case is broken.
The Kohler has a wiring pig tail with 4 wires. They almost look like a trailer wiring plug; I believe I saw brown, green, white and yellow. Seems 3 of the wires were on one harness, and the white wire was on its own.
I'm guessing all I really need to do is wire + battery wire to starter, through a relay, and ground from battery. Shouldn't be any more wiring to worry about other than that????
Can I leave all my Kubota wiring and just make sure the power & ground from battery connect to Kohler? Guess I'm confused about this pigtail/harness coming off the Kohler.
thanks. :)
   / LT 155 Kohler 15hp wiring Qs #2
I have a couple pictures of my lt155
Here
Clean Tractor
Page 8 it might help you out a little.
Rob
OMG!!!!!!!!!!!!! 10 years old and it's that spotless?? I think I'm greener with envy than the color of your JD!! That is beautiful.
If I PM you, could you possibly email me copies of your last 2 pics? I was hoping I could zoom in and get more detail. I see 3 or 4 wiring relays and those have me a bit concerned. Now I'mthinking I should have been more patient for a replacement Kawi engine.
thanks for that.
   / LT 155 Kohler 15hp wiring Qs #4
thanks, i sent you an email from my home email.
   / LT 155 Kohler 15hp wiring Qs #6
You should have the pictures.
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55218)
GMC 3500 Extended...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
