LT 1050 Steering is skipping
   / LT 1050 Steering is skipping #1
Fish4um
Magnolia, Delaware
Cub Cadet LT1050
I have a LT1050 and the steering is starting to skip. It feels like it's skipping the teeth on a gear. The steering wheel is real sloppy. What could be the problem?
   / LT 1050 Steering is skipping #2
Check parts #10 and #11 on this diagram for missing teeth. Also make sure #11 is tight on shaft.
I checked the gears and all looks good. There must be a bushing gone bad. When I move the steering wheel it woobles side to side. I will pull it apart to check. Didn't have time last night. Thanks for the input.
Oldmachinist,
I pulled it apart this weekend and it's a $3.50 bushing that is worn. I also bought a new gear. The old one did have a small groove in in it. Thanks for your input.
   / LT 1050 Steering is skipping #5
We had that bushing replaced on our LT1050 last summer. However ours had stripped the small gear and chewed up the big one. They replaced all 3 (2 gears and a bushing) and the drive belt (which was shot) while they were in there.
Aaron Z
   / LT 1050 Steering is skipping #6
Well it seems I have the same problem as of today. Over time the steering got sloppy but today just about finished mowing I heard the gears skip. So I stopped checked and the rod where the steering gear is on seems a little loose going back and forth and away from the 2nd larger gear area. So from posting its seems the bushing is shot and of course probably the steering gear worn. My question is having done this, is it something a homeowner can do at home without a lot of grief? Is the bushing area easily accessible? Seems from the diagram its from the top side verus the bottom side where the gear and lock nut are on the stearing rod. Thanks for any guidance. There goes part of MEM Day weekend. Also I presume its best to take the mowing deck off too for easier access and can a car jack be used to prop up the mower or should be enough room to get my fat fingers under there to unbolt and rebolt the gear back on?
   / LT 1050 Steering is skipping #7
I would use jackstands or ramps to hold the mower up while I was under it, but otherwise you have the basics down.
Deck must come off to get at everything (unless you are a contortionist).
Aaron Z
   / LT 1050 Steering is skipping #8
Per anothe rpost that gave goo dinstructions in this forum, it took 30 minutes and $10 to fix by replacing the steering shaft gear and bearing type nut on the steering shaft. Take off the steering wheel to help lift the shaft out to put on the bearing type nut and so. Glad I avoided having the dealer come do it for such a quick cheap fix. She turns smooth now.
TCM FD30T6T Forklift (A55973)
TCM FD30T6T...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
More info coming soon! (A56859)
More info coming...
