Oil & Fuel LT 1050 Oil Change
   / LT 1050 Oil Change #1
Rickstir
Hard by the Elk Fork of the Salt River, Missouri
2009 Mahindra 4110
Can the engineer that designed the location for the oil drain valve please stand up? I have a few words for him.
Like: Why did you put the starter directly in the way of the oil change valve? Doesn't any one of you engineers try to work on these machines during mock up? Don't you have an advisory board to give you feedback on some of your screwy designs?
Also: Why not make the valve stick out far enough so that someone with hands perhaps a little bigger than a prom queen can get to it?
Surely somebody makes an extension for this abomination.:mad:
   / LT 1050 Oil Change #2
Sounds like my TroyBilt 18.5 HP Bronco with steering linkage and floorboard in the way
I will put a flex hose on mine
   / LT 1050 Oil Change #3
It always boggles my mind how these things always happen with all things internal combustion engine! For instance, the fuel canister location housing the fuel filter in my dodge 12valve cummins diesel 2500 truck! Fowl lanquage is always in order during a filter change!
   / LT 1050 Oil Change #4
Take the engine out of the unit and set it on a bench. I bet the oil drain is very accessible. The problem lies in all the different applications the engine is used in. Do not blame the engine company for hard to reach items.
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
1408 (A57192)
1408 (A57192)
2006 International 4300 2,000 Gallon Fuel Truck (A55852)
2006 International...
(APPROX.48) UNUSED 2X4X10 PREMIUM GRADE LUMBER (A57192)
(APPROX.48) UNUSED...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
TURN PLOW (A57192)
TURN PLOW (A57192)
