LS3039 wont' start / Buzzing sound from under dash
   / LS3039 wont' start / Buzzing sound from under dash #1
Bigbear123
South Central Missouri
LS 3039
I have a LS3039 shuttle shift tractor. I have had it about ten months. Have been real happy with it until now. I pulled it into the yard to wash some bird mess off of it. When I went to start it, all I get is a buzzing from under the cowl. I have done some reading and it sounds like maybe a glow plug timer has gone bad. I have good voltage from the batteries. All the fuses are good, but it wont' turn over. When you turn the key, it does nothing. If I unplug the timer, will I be able to turn the engine over or does it have to be in the loop? Any input appreciated.
After pulling my hair out a while. Decided to go back to basics. Took the battery cables loose. They looked good but cleaned them anyway and connected back to battery. Just for good measure I put a wrench on where the ground cable connects to the frame. Guess what, it was just a bit loose. Tightened it up. The tractor fired right up like it should. No buzzing from the relay.
   / LS3039 wont' start / Buzzing sound from under dash #2
The electrical issues I've seen related to bad grounds are too numerous to recall.
Getting into the basics is always the right tactic. Good job.:thumbsup:
   / LS3039 wont' start / Buzzing sound from under dash #3
Almost every time I get a no start from any of my equipment it due to a loose connection.
Even yesterday my Z clicked when I turned the key. I checked the date issued from TSC, I know I know, 5 YRS AGO.
Anyway, I charged it overnight and the next day I drove away. No worries.
Today, same click. Grrrrr
Checked voltage and Fluke said: 13.25vdc
Huh?
Took leads off wire brushed them down to even the washers and it fired like a showroom queen.
That 2003 model just purred.
Check your connections, Guys!
   / LS3039 wont' start / Buzzing sound from under dash #4
Start with the simple check both battery connections, then move onto checking all the fuses to see if you have a Fuse that blew maybe cause of water getting into a connection some where on the tractor during the wash.
Case 1020 25ft Draper Head (A56438)
Case 1020 25ft...
2015 Bobcat S650 Skidsteer - Enclosed Cab - 5462 Hours (A56438)
2015 Bobcat S650...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 Ford F-250 4x4 Pickup Truck (A60460)
2012 Ford F-250...
2022 John Deere 1025R (A53317)
2022 John Deere...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
