LS XU 6168 No Start
   / LS XU 6168 No Start #1
BulFrog
LS XU 6168
Having some issues with forward and reverse Lever. Yesterday it started in reverse, had code F04 106 flashing and was low on power.
Parked and let set overnight. Then today No start in any position of lever.
Can anyone HELP.
   / LS XU 6168 No Start #2
Neutral safety switch? Or its equivalent sensor in the drive circuit?
Thanks for you help.
I will see what I can find.
   / LS XU 6168 No Start #4
Is your warning light on? Solid Red? On my xr4150 that code/light combo indicates either P0106 - intake manifold absolute pressure sensor signal drift fault, or P0107 - intake manifold absolute pressure sensor signal low fault.
warning light was on when tractor was running.
but not with just switch turning today. Undone battery to set over night.
Ordered Service Manual today, maybe this will help.
   / LS XU 6168 No Start #7
Is the battery fully charged? ECMs can get really wonky when voltage drops or fluctuates.
Sorry for delay. LS is back running. Bad neutral switch, with a blown horn relay fuse that was messing with voltage.
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2020 DRAGON ESP...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2012 POLARIS SPORTSMAN 500 H.O LIMITED EDITION ATV (A60432)
2012 POLARIS...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
