Texasmark
Elite Member
- Joined
- Apr 24, 2012
- Messages
- 3,758
- Location
- N. Texas
- Tractor
- Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
I don't want to throw sand in your face for leaning to Branson, heck no, but if you are that interested in stability, ensure that you fill at least your rears with the fluid of your choice per the accepted process, material, and fluid level. Fluid puts weight on the ground where it's as low as it can be and goes a long way in lowering your center of gravity which is what you need to keep between your rears where they touch the ground to stay upright. I'm doing it so that I don't have to worry about over taxing my front drive line when on a hill with a good load in the bucket, and to add weight to the rear for a softer ride without having to drag around a counter weight all the time. Additionally, this way, I don't need to remove anything when it's mowing season and I hook up my mower.
On the subject, I just bought fluid to fill my rears on my newly purchased 2400. Looked and thought and wound up with WW's RV fluid at $4.75 a gallon rated to -50F full strength. Figured I could dilute to something around 0-F for my climate here and come out with a good fill product at a cheap price.
On the filler hootus, somebody on here in a post that has appeared online under the question of filling tractor tires, mentioned that they bought an attachment at Gempler's that allows you to hook your garden hose connectors to a clear water pump and pump in the fluid. When desired, push the air release button on the hootus to let the compressed air out so that you can install more, without having to undo everything. So I www'd them today and sure-nuf that plus shipping, $15.
