Comparison LS XR4145HC VS Branson 4720CH
   / LS XR4145HC VS Branson 4720CH #1
ursa
Newberg
none
Been doing some research on what to purchase and have narrowed it down to the LS XR4145HC and the Branson 4720CH. Both are about the same price around 28k with FEL and Cab. I will be getting R4 tires. Both companies have dealers close enough to home. I am really having a challenge deciding because I have not had enough experience with either.
Pros of the LS 4145HC:
- Appears to be a little more refined in terms of design.
- Greater lift capacity
- My impression is the company has deeper pockets thus more staying power when times get tough
- I am hearing less complaints in terms of repairs but this may be entirely anecdotal evidence, I really have no real numbers to go by.
- Transmission/ Engine Quieter than the Branson
Pros of the Branson 4720CH:
- Simpler, less computerized, so perhaps less likely to have an electronic related failure that i cannot figure out.
- Has a couple extra HP and looses less HP through the PTO
- Has the ability to widen out stance of rear wheels (The LS with R4's are not configurable to different widths).
- The tractor itself (without cab) is a couple hundred pounds heavier, however the cab version of the two tractors is not that different in weight though, not sure why, makes me wonder if the build quality of the cab is not as good on the Branson.
I have aprox 20 acres, part of which is hilly and heavily forested. Tractor will be used to maintain about a mile of gravel roads, will likely get a road boss or grademaster 6ft grader. Will do some logging work, move dirt, dig, and bush hog.
My biggest priorities are low center of gravity and having a good width, and getting something that will have a reasonable resale value later in case I move. I also dont want to have a major failure right out the gate or right after the warranty period and its hard to tell which brand is better in that regard..
Appreciate any insight you may have on any of the bullet points above! Thanks in advance!!
   / LS XR4145HC VS Branson 4720CH #2
* Disclaimer-I bought a Branson 4520C
Although I didn't really look at LS in person (the nearest dealer was 70 miles away), I did quite a bit of research on many different brands.
The reasons I went with the Branson were similar to your pro list:
-Simple non-computerized Cummins-esk engine with mechanical fuel injection
-Simple Tier 4 strategy; large catalytic converter (DOC) vs smaller DOC w/ regeneration cycles
-Two speed PTO
-Standard dual rear remotes
The things I don't like about the Branson
-Cab interior quality is like a Korean economy car from the early 1990's
-Noisy at PTO speed (I still wear hearing protection)
-Long term health of company and future of parts could be a headache
I think either way you will be happy. It seems the Koreans like to pack in many features and price their products reasonably.
   / LS XR4145HC VS Branson 4720CH #3
I had really good luck with my LS, and tend to think they're a stronger company, with more dealers, and growth potential than Branson at this point, but they're both decent machines.
More important than anything else is spending seat time in the machines to see what you like, and don't like. Something that you can't stand might not bother me, and vice-versa. Either machine should be able to handle the tasks you've outlined, so I wouldn't worry much about that part.
   / LS XR4145HC VS Branson 4720CH #4
I don't think you will have to worry about Branson being around or getting parts. Branson has teamed up with McCormick and Landini to supply them their series 1 tractors.
   / LS XR4145HC VS Branson 4720CH #5
Branson also released a new series in the last few months. My local dealer has sold some of the new 15 series Bransons.
   / LS XR4145HC VS Branson 4720CH #6
Not the same model but I recently spent a lot of time comparing a XG3037 to the 3520h and ended up with the Branson. The Branson cockpit and controls fit me better, tractor seemed more stout and pricing was better as well.
   / LS XR4145HC VS Branson 4720CH #7
Both LS and Daedong (Kioti) also supplied compacts for McCormick within the last 5-10 years, so I wouldn't put too much stock in Kukje (Branson) having long term success based on that relationship.
To the OP, I have been on both machines, and owned a couple LS tractors a few years ago. I think they are both good. I like how heavily built the Branson tractors feel. However, I've sat in the Cabs of every CUT in the market, and I feel like the Branson cab on these CUT's is the worst in the industry. It felt extremely cramped, and the layout was strange. Of course that is personal opinion, so I'm sure someone may disagree... But that was my feeling on it.
That aside, I would think that at this point, LS is on a roll and has more "staying power" than Branson. LS prices are going up, and when I traded my first LS, and sold my second one, I did not notice any hit on resale that was worse than any other brand.
If you have good dealers for both, the choice will be tougher.
Did you notice any "comfort" differences?
Thank you to those who have replied so far! The LS dealer here has the cabbed model, unfortunately it is not HST, but its given me a good idea of the tractor. The Branson dealers do not have the cabbed version available for me to look at so I have not been able to inspect the cab. I guess this is an issue when working with lower volume dealers, you may not be able to inspect the exact product you are going to buy. I have driven the 4720 HST and it felt ok, was just a bit noisier than I expected. I will have to go back to the dealers and really get more of a feeling for the layout differences. The FEL operation of both seemed responsive enough but honestly I havent used FEL's enough to know exactly how to compare them well.
   / LS XR4145HC VS Branson 4720CH #9
You are absolutely right that both Kioti and LS supplied compact tractors to McCormick. Both companies got better visibility of their products through the partnershipand and both seem to be doing quite well now.
I was referring more to the fact that these partnerships usually have a minimum 5 year duration with a renewal option. That means Branson parts and service should be around for a while, in case that was a concern.
I've sat in the 4520 cab version (version before 4720) and found it tight. I also found the tires came up to close to the fenders which made putting chains on an issue (we get 4-5 monthes of winter)
   / LS XR4145HC VS Branson 4720CH #10
If Branson's time is about up, what are all the rainbow brands that it makes going to do for a manufacturer? Sorry guys, gotta disagree with you again.
On the cabs, I can't say about the 4500 series, but I'm 6'5 and 250 and one of the reasons I bought my 2007 6530 4wd with FEL was the comfortable, roomy cab, handy controls, tilt and telescoping steering wheel, hydro steering, shuttle, 24 F and R gears, washers and wipers front and rear, inside rear view mirror, outside rear view mirrors, choice of type of PTO with a selector switch, 3 PTO speeds, pin held exact location lift arm braces (no flopping around, exact positioning) lift arm extension tips (gives you about 2" of fore-aft slop, FEL remotes and 2 sets aft, flat floor, exhaust stack off to the side, not in your face, air compressor (in the seat) operated cushion, high back with armrests cloth seat (actually a chair), and the clincher was the 3 pt control lever right at the rear where you hook up (in addition to the normal one inside the cab)...no more having to run back and forth when working alone....it's all right there for you.......and it's all standard equipment with a 4 year bumper to bumper warranty......oh and a Cummins B 3.3 NA direct injection, naturally aspired engine to boot.
Yeah, any day now and they are going to be in the ditch.
2021 CATERPILLAR 289D3 SKID STEER (A51242)
2021 CATERPILLAR...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
HOPKINS 40 TRI-AXLE DATA VAN TRAILER (A50854)
HOPKINS 40...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2016 Ford Explorer...
1985 International X Con Semi (A50514)
1985 International...
