LS xr4140 powering down on its own ,
   / LS xr4140 powering down on its own , #1
3gunr
wentzville mo
mahindra 2538 mahindra 2810 cub cadet 7260 massey 255
This is my freinds tractor up at our farm, It has done this in the past when he is bush hogging and the air filter and radiator gets plugged, When he stops and blows it out it runs fine, well it started doing it after he cleaned it good so he bought new filters and it did not help , he told me it has only regened 1 time in 250 hrs , I told him to do a forced regen but that did not help, The tractor will just drop rpms down on its own and has little power. He says the temp gauge is normal and fluids are full any ideas?
   / LS xr4140 powering down on its own , #2
Clogged fuel tank vent? I believe these vent through the fuel tank cap. Might be worth checking it out.
That could be it , It has been so dry up there the last 2 months just driving the tractor anywhere creates clouds of dust that choke ya, I will pass that on to him.
   / LS xr4140 powering down on its own , #4
You ain't kidding and you guys got more than we have.
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2019 Ford F-550 Altec AT41S 40ft. Bucket Truck (A55973)
2019 Ford F-550...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A57453)
2013 International...
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
2022 Ram 2500 4x4 Crew Cab Pickup Truck (A55973)
2022 Ram 2500 4x4...
